slow front wipers
Old Apr 8, 2012 | 06:46 AM
bad34's Avatar
Default slow front wipers
hi recently my wipers started wiping really slow on my 2003 a4 tdi sometimes not even completing the full wipe cycle they would stop n freeze half way across the screen so rather than start swapping out motor n linkage I just gave all areas a good spay with wd40 on motor / linkage and all is now well so I hope this thread will be usefull to someone even if only a temp/cheap fix
Old Apr 9, 2012 | 05:32 AM
jmarshall098's Avatar
Definitely, it is better to oil them rather then spending on replacing the motor. Good suggestion. Thanks.
Old Apr 9, 2012 | 02:52 PM
MKE_Audi's Avatar
You need to take out the linkage and clean and lube the spindles for each wiper. Common problem, had to do so with my 2003 a4.
Old Apr 10, 2012 | 12:42 PM
bad34's Avatar
well for now they are working well but if the problem comes back I'll be sure to try that Thanks
Old Apr 12, 2012 | 04:21 PM
MKE_Audi's Avatar
I was thinking the same thing when mine started having troubles. And then about two weeks later it was siezed...
If you have the time, they come out much easier if you can move the spindles still before they totally sieze.
Since mine were siezed I ended up bending the whole assembly trying to get them out. cost me another $100 for the wiper assembly arm eventually.
Good luck!
Old Apr 13, 2012 | 07:38 AM
bad34's Avatar
that was my intention untill i seen how tight it looked to get out that's why I went for the easy option lol but as I said they are working good as new for now
Old Apr 13, 2012 | 11:28 AM
jdahlen24's Avatar
If you can rent a front end puller kit, they usually come with a puller that works really well at popping those wiper arms off the spindle. If you can clean up and lubricate those spindles that'll save you from having to purchase a brand new wiper assembly.
The assembly on my B5 were so rusted that I had to go with a brand new assembly, to the tune of about $120.
mecaniccpa
Apr 10, 2015 09:59 PM
a3square
Mar 14, 2015 04:18 PM
zulunation
Aug 3, 2010 11:26 AM
tonyk
Feb 24, 2010 07:03 PM
Amze
Jan 29, 2007 08:05 PM
