Some engine problems
Old Oct 22, 2008 | 07:41 PM
dmansr25sd's Avatar
Default Some engine problems
So this morning I drove like 5 minutes and stopped to drop someone off and immediately following as I went to pull away the car started to shake violently like at somewhere around like 5-10hertz. It felt like a piston wasn't firing and the power dropped significantly and obviously i took the gas very easy. I drove it home because I was like half a mile from home and it was still running fine, of course the check engine light came up.
I checked the oil while i was at it and it was full and clean, the exposed belts were all in place and tensioned. I haven't gotten around to checking the wiring to check for loose connections.
I am guessing either like a spark plug or wire connection or something that is dealing with the firing sequence. Any thoughts/suggestions?
Old Oct 22, 2008 | 08:13 PM
krystallbluea4's Avatar
Its a coil. Trust me.
EXTRA
May 24, 2012 06:55 PM
Jake2.0T
B7 Models
Nov 7, 2011 11:57 PM
maniorta
Apr 18, 2010 12:39 PM
painted600rr
Jan 9, 2008 03:08 AM
JohnnyPG
Apr 29, 2007 12:54 PM
