Tail lights
Old Apr 9, 2010 | 10:03 AM
AudiKid12's Avatar
Default Tail lights
how do i take off my tail lights on an A4 1.8L is there screws? or
Old Apr 9, 2010 | 10:29 AM
shane.trammell's Avatar
there are small round covers inside the trunk, pop those out and then there is a bolt or a nut. its easy.
Old Apr 9, 2010 | 10:38 AM
AudiKid12's Avatar
so no brain surgery, YES.. thank you for your hlep
Old Apr 9, 2010 | 10:52 AM
most things are pretty easy, just take your time and youll be good.
Old Apr 9, 2010 | 06:41 PM
fg_carz18's Avatar
I am having trouble with my tail lights, it sends error to my dash board. It says all my lights are out even if its working fine. Both driver and passenger side are sending error =/. Used to have LEDs on it but when this happened, I replaced it with bulbs but it still sends error.
Old Apr 9, 2010 | 06:57 PM
idk about that.
Old Apr 9, 2010 | 09:28 PM
Dan1969's Avatar
If you put LEDs before you must have had an error all the time, now if it's telling you to check your D/S or P/S brake light make sure you're putting the bulb in the correct slot, also sometimes the little receptacle gets crusted up with corrosion or doesn't make full contact with the bulb.
hoovdiddy
Jul 5, 2017 10:19 AM
FishEye
Mar 25, 2012 03:13 PM
TagsAudi
May 31, 2007 05:55 PM
mypreludeisred
Aug 9, 2006 11:08 PM
