timing belt
i have a 2004 audi quatro 3.0 convertible. when does the timing belt need to be changed? how much does it usually run? what else is needed or goes at 100k? does the auto tranny need to be serviced?
ty rick
ty rick
What is your mileage? Do you have the car manual hidden on the compartment underneath the steering wheel? If you find it, then it contains details about your maintenance schedule.
I have an 03 B6 A4 Avant and the manual said the timing belt must be replaced at 105K miles. However, I have read in these forums and elsewhere that replacing the timing belt at 80-85K is smarter, so that you can avoid the heartache when a 'premature' timing belt failure actually do happen.
If you dont know when it was done as you are a new owner, have it done. If you just haven't had it done and it's at 100k DO IT NOW! I had one break on mine and Just parts and machine work was $2200. A $7-800 service is cheap.
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
