Transmission drain and fill or flush. No vag com!?
Old Dec 17, 2012 | 11:20 AM
2003audiA4avant's Avatar
Default Transmission drain and fill or flush. No vag com!?
I have an issue with a bucking feeling when engine/tranny is cold. Specialized Audi shop said internal transmission was the culprit. I tried pumping some BG transmission conditioner in and it improved the buck. Although Audi ATF is "lifetime" I am going to drain, replace filter/gasket, and fill.
I bought a kit from Blauparts.com and have all the tools to do the procedure... EXCEPT A VAG COM. I have heard I can buy a cheap amazon 10$ cable and use that with vcds lite. If so can someone link the right cable?
Otherwise I am going to try without one. I have seen a couple posts but not one without a vag com. My basic procedure is going to be to add some bg tranny cleaner and drive the car for a couple minutes. Then remove drain plug and drain. Next, remove pan and filter, and clean pan. Replace filter and pan. Remove fill plug and pump fluid until is runs out. Then have someone start the car and let idle while I pump more fluid. Then they go through the gears (10 seconds each) while I fill. Go through gears again while I fill. My only issue is I'm not sure when to stop. I know it should take about 5/6 quarts. How long does it take until the tranny fluid reaches 40 degrees Celsius? I do have a laser thermometer that might work (point at tranny pan).
Any help/suggestions is much appreciated!
Old Dec 19, 2012 | 12:09 PM
NoAudiGuy's Avatar
If no VAGCOM use a digitial thermometer to monitor fluid temps.
Old Dec 20, 2012 | 10:25 AM
By measuring the pan? Because you can't reach your thermometer in the pan to reach fluid
Old Dec 21, 2012 | 07:12 PM
Dan1969's Avatar
Just drain and refill. You can also do a flush. If this only happens when the car is cold, let it warm up a little longer before driving...
Old Dec 23, 2012 | 07:58 PM
So i bought a 13$ cable and luckily I can now see the tranny temp. Im going to do the flush and fill sometime in the next couple weeks.
madridlover
Aug 14, 2008 11:11 PM
discontained
Oct 21, 2007 10:53 PM
SMoLiK
Jan 25, 2007 01:25 AM
seabassx
Nov 14, 2006 02:14 AM
s4ddriverr
Aug 25, 2004 11:59 AM
