Transmission Range Sensor or TCM.. URGENT HELP REQUIRED!
Old Jan 11, 2025 | 12:51 AM
marteA4's Avatar
I replaced the Transmission range sensor ( on the side of the gearbox ) on a A4B5 v6 2.4 & while it wasn't easy. There's not much space & you want a low profile thru hole rachet with a torx bit, it's not near impossible if you have good access under the car.
I took the old range sensor apart & it had broken up inside into a bunch a pieces.
unfortunately replacing it exposed a different problem & by using a cheap rosstec OBD2 I find that it's not detecting 3 solenoids in the gearbox, so I expect theres either connection problems in the loom to the gearbox. Or the silly plastic printed circuit strip connector inside the gearbox that pushes onto the solenoid connections. I think I have this problem in two b5 v6 cars.
And I need to replace the transmission range sensor in a B6 3.0 too. ( Different plugs on the end, the By has a flat plug. The b5 has a round plug.
gixxsta04
Jun 21, 2011 06:36 PM
gixxsta04
Jun 13, 2011 08:14 PM
ZeroAudi
Apr 27, 2011 04:53 PM
jpcallmotor
Jul 9, 2010 01:41 PM
porschefan
Sep 9, 2009 12:54 PM
