P0722 Output Speed Sensor No Signal - TCM problem
Old Jul 24, 2010 | 05:12 AM
ZeroAudi's Avatar
Default P0722 Output Speed Sensor No Signal - TCM problem
Have a question...
I have a 2005 Audi A4 and the MIL is on.
My symptoms are as follows:
Transmission first started switching into S gear on it's own while driving on the freeway. Then when I was backing out of my driveway, it slipped out of reverse and into neutral. Re-shifted gears and it started working fine, except the PRNDS started flashing and continued to flash until i turned the car off. Now it has been shifting into S gear more often when I'm on the freeway and will not shift into any other gear when that happens.
I had it scanned and it was a P0722 - Output Speed Sensor No Signal.
I've read on other forums that there may be multiple speed sensors that will give that OBDII code?
Or that the Output Speed Sensor is actually connected to the TCM and that the TCM itself needs to be replaced? Is that true?
Can a bad output speed sensor cause those symptoms? Or does that sound more like the TCM itself?
I've taken it back to the dealer I bought it from because they said they would fix whatever problem was causing the MIL to light up. They said that they are going to replace the sensor. I'm wondering if replacing just the sensor will fix the problem or not...
Thanks for anyone's advice...
Old Apr 26, 2011 | 10:52 PM
kbayern's Avatar
Default Did you get fixed?
What ended up happening with this repair? I have the EXACT same issues right now...am being told that I may need a new transmission on a car that has been babied and only has 42K miles...please advise.
Thanks.
Ken
Old Apr 27, 2011 | 04:53 PM
ZeroAudi's Avatar
Yeah Ken, it turned out to be the TCM. The transmission shop replaced the TCM (a $2,000 fix) and now it works perfect. They did not have to replace the entire transmission. Hope that helps.
adrianaborek92
Dec 13, 2017 04:51 PM
Bill Davis
Oct 31, 2013 02:59 PM
adrianaborek92
Apr 1, 2013 12:27 AM
RK911
Jun 20, 2012 08:27 AM
shavrovas
B7 Models
Dec 30, 2011 06:32 PM
