Trying to diagnose problem with driver power window
i would say its the motor. but had your window shown any signs of going up and down slowly. It also could be the regulator if u hear alot of binding inside the door. Heres the diy to get an idea of what you are looking at?
DIY: B6 A4 Window Regulator & Motor Replacement
Hi,
Just curious, what was the faulty component at the end? I have the same issue on my car too. And my window is stuck down! :-(
Everything works except for the mirrors and driver side window. I'm assuming it's a power issue as none of the switches are lit as well. Any help is appreciated :-)
hi,
i have an 02 audi a4 and the problem is that my driver side window isn't working.
it happened today itself when i used the switch to get my driver side window up. the window was to close properly when suddenly i heard an unusual sound when it reach on top. it made a "tac" sound. i tried to get the window down but it was blocked. the window motor seem good. can u please help asap. thx
Hey Pa4ul, I saw you mentioned something about the light on the window switches going out, my switch for my drivers side front window stopped working and also my mirror adjuster stopped working but all of the other switches work on the the driver side front door. My light has also went out. Do you possibly know what could have caused that? I would really appreciate that help!
Hello I also need help. -03' A4 B6 3.0v- windows go down but can't control them off the driver door only on each door single handedly. Can hear the motors run but no movement when switches are applied. any thoughts ? Thank you very much
tkltian
Nov 24, 2010 03:56 AM
