TURBO for 1.8 quattro
Old Mar 9, 2010 | 07:52 PM
awebocompa's Avatar
Default TURBO for 1.8 quattro
can any 1 tell me how much the turbo kit for the 1.8 cost and were can i get one, the turbo on my audi broke so i have to get a new one....
Old Mar 10, 2010 | 10:04 AM
olstyn's Avatar
Here's one option. It's a direct replacement for the OEM turbo. Obviously if you poke around on that site, you can also find upgraded options that'll make more power, etc, but that's the stock turbo and the gaskets & studs you need in order to replace it.
I'm not going to be much help diagnosing, but I'm sure when other people with more expertise come along, they'll want to know what makes you sure it's the turbo and not a boost leak or some sort of fault that has the car in zero boost limp mode. Just thought I'd throw those other possibilities out there in case you hadn't thought of them and/or hadn't investigated them.
Best of luck with getting it fixed.
Old Mar 30, 2010 | 01:50 PM
mightyb28's Avatar
Default turbo replacement
I find the K03's for $250-350 online. Cheep. Call your local audi tuner shop. They will have used ones all over the place as people upgrade them constantly. Ebay has them all over too.
Old Mar 30, 2010 | 02:12 PM
pa4ul's Avatar
check ebay. Searched around this morning and the first thing that poped up was two ko3's with all the corresponding hardware. OR u could lurk the classifieds
Old Mar 31, 2010 | 12:46 PM
CMoriart's Avatar
Speaking of Turbo's.... What is the major difference between the K03 and K04?
Old Mar 31, 2010 | 06:11 PM
mightyb28's Avatar
Post
$2000 (turbo, injectors, ecu chip) and very little. Pick up a gt25 and do it right. The K03 will only provide about 30hp more. Not worth it in my book. Get a turbo that will optimize your engine internals. The gt25 is also smaller then the GT28 and will spool faster. It will bolt onto your current OEM plumbing too.
http://www.turbo-kits.com/turbochargers.html
Old Mar 31, 2010 | 10:51 PM
olstyn's Avatar
Given that the K03 is the stock turbo, I assume you mean the K04 provides about 30 HP more.
Old Mar 31, 2010 | 11:31 PM
turbo kraut's Avatar
Tech Guru
if you want a stock k03 i have one off my 01 in really good shape, if you want an upgrade, gtrs or 2871 full body are really good upgrades....ringer-racing.com
Old Apr 1, 2010 | 11:20 AM
mightyb28's Avatar
My bad and you are right it is the K04 i am speaking of.
Just make sure if you are going to switch turbo's that you search the forums and see some review and get a proven turbo. Also make sure you put in a new full sized intercooler as the OEM's are just for the K03 and in fact they don't do a very good job of the intake temp. I believe Eurotuner did a IC upgrade on a stock turbo and saw significant cooling and way better upper end performance on even the stock. So get the intercooler done first then pick your turbo. I am still a fan of the small gt25 with its smaller size and faster spooling. Turbo lag is annoying!
Old Apr 2, 2010 | 01:53 PM
Mike-2ptzero's Avatar
GT25 and GT28 are basically the same turbo, they just dont use the GT25 name anymore but you can find it on the CHRA of a GT28r.
GT28r was just a GT25r renamed many years ago. GT28rs and GT2871r are slightly larger. ATP tends to use a GT25r CHRA on their GTRS elim kits.
Either of those will bolt to the stock manifold, only the Elim kit is designed to do that. The elim kits also put the turbo close to the same spot as the stock k03 setup. So the turbo outlet hose and cat/down pipe will all bolt right up. If doing a standard GT28 turbo a new manifold will be needed and this will put the turbo in a different location.
