Turn Signals Osciallate Between Right and Left
This is a very odd problem that I'm having difficulty diagnosing.
I have a 2002 Audi A4 that I recently purchased. It's in pretty perfect condition, except for this turn signal business. Every now and then (several times per drive), when I activate either turn signal (fully clicked into position, not just holding it for a lane change), my turn signals oscillate (on tempo, neither too fast nor slow) and then fix themselves - they'll blink left, right, left, right, left, left, left... I've been pulled over once already for improper signaling. No ticket, but still. I'm not a car guy, so I don't really even know where to start finding the problem. Any ideas? The ECU has been upgraded, although not by me and I do not know which unit he selected. Could that be the culprit? |
Sounds like the turn signal relay. Dont know where its at on your car, however. You can turn it on and listen for it though.
You know if you just move your clicker to the position it'll click 3 times on its own, without locking it or holding it in place, if you move it the other way it'll finish the clicking and then go on to the other side on its own. But if you're just moving the arm to one side and your lights are still blinking both sides I would check the relay (clicker) thingy.
You know if you just move your clicker to the position it'll click 3 times on its own Sounds like the turn signal relay. Dont know where its at on your car, however. You can turn it on and listen for it though. if you move it the other way it'll finish the clicking and then go on to the other side on its own L R L R L L L L ... It sounds like if we think its an automatic three-blinks thing, then, as you said, wouldn't it "finish and go on to the other side on its own" ? What might I do to help diagnose if this is the relay or not? |
I got a L, L, L, then R, R, R, nothing in between. Try changing the clicker or look in your fuse box make sure that all fuses are fully inserted.
Quote: Sounds like the turn signal relay. Dont know where its at on your car, however. You can turn it on and listen for it though. The other thing it could be is the switch in the stalk itself. |
