Uncommon coolant leak
Old Jan 6, 2010 | 03:25 PM
dvmbound1977's Avatar
Default Uncommon coolant leak
I have an antifreeze coolant leak around the driver's side of engine. Near oil filter. Possible thermostat? Don't see any around the tstat though. Oil cooler? Has anyone had any problems like this?
Old Jan 6, 2010 | 05:08 PM
pa4ul's Avatar
check in the rear of the engine before the firewall. Coolant flange could be cracked.
Old Jan 6, 2010 | 09:14 PM
That was the 2nd place I checked after the radiator and hoses. Do not see any buildup but the only place I see any antifreeze is around the oil dipstick and oil filter area. None in front or behind (other that blowback). Any other suggestions? I want to avoid removing everything to try and find the cause but if I must, I must. Poor Gretchen.
Old Jan 6, 2010 | 10:55 PM
CMoriart's Avatar
Default Good Call..
on the idea of the coolant flange. Just had mine replaced a week ago. Been smelling it since 06.
Old Jan 6, 2010 | 10:58 PM
CMoriart's Avatar
Head gasket? Does the oil look "milky"?
Old Jan 7, 2010 | 11:13 AM
pa4ul's Avatar
Isnt their a plug that tends to corriode leaking coolant. i think its somewhere underneath the manifold. Anyone have any thoughts or conclusions?
Old Jan 7, 2010 | 01:02 PM
Oil looks fine. Due for a change but normal. The leak is only coolant with no signs of oil contamination. Isn't it somewhat abnormal for a head gasket issue? About the sensor, I am not sure but I do not see the root of the problem. Where is it located? Any guesses or ways of locating it. My coolant level has stayed pretty normal although dropping minimally.
Old Jan 8, 2010 | 12:02 PM
pa4ul's Avatar
http://www.a4mods.com/index.php?page...tml&category=5
theres the location of the sensor sir.
Old Jan 15, 2010 | 11:23 AM
Found the issue. Freeze plug near the thermostat. Uncommon? I have seen some other posts on this. All the other common leaks are fine (nonexistent). May be something to review. I had the work done at a shop due to time constraints. Is there anything else I should be concerned about that may have caused this?
Cioffie
May 19, 2013 10:24 PM
inventorA6
Apr 15, 2009 06:46 AM
bradfish
Dec 23, 2008 05:06 PM
less_of_me
May 2, 2007 03:29 AM
ckandes1
Nov 21, 2006 07:24 PM
