v belt tensioner vibration /rattle
Old Sep 9, 2012 | 10:49 AM
irishaudi's Avatar
Default v belt tensioner vibration /rattle
hello all,
recently posted a video here about a strange noise im getting in my 2002 a4 1.8 amb,
only happens when car is in gear- just as clutch is released, a sort of rattle humming sound.
anyways finally traced the noise to the tensioner on the v belt,replaced tensioner and problem still persisits.
you can actually see the tensioner flutter as the clutch is released and engine comes underload,if i hold the tensioner with a visegrips the noise goes away,it only last for the innitial few seconds as the car goes into gear then disappears.
my mechanic who i trust for years is also dumbfounded by this, we put two tensioners in- first a dayco and then a dealership one, but the noise is still present.
he believes for some reason the v belt isnt getting proper tension and is actually slacking causing the flutte/r vibration for those few seconds, maybe an internal fault??
sorry for long post, hope someone can finally chime in.
Old Sep 9, 2012 | 11:50 AM
z28pete's Avatar
Are you sure the engine is not misfirig as it coes under load, or maybe the clutch is chattering?
Old Sep 9, 2012 | 11:58 AM
irishaudi's Avatar
No misfire, no clutch problem, like i said if i clamp the tensioner and put force on it the noise stops. Ill try an video again and post
Mossyoakglock
Sep 13, 2013 11:11 PM
jinsojoo
Oct 30, 2012 11:22 PM
rcheing
May 24, 2012 12:08 AM
corky
Jul 7, 2008 08:08 AM
