Valve rattle @ 2000 RPM? 1.8t
Old Jun 1, 2009 | 07:21 PM
overland04's Avatar
Default Valve rattle @ 2000 RPM? 1.8t
I have this new rattle that starts at about 1500 RPM and goes to 2000 RPM. It sounds like a vibrating heat shield but its coming from the cylinder #1 area. Are the valves adjustable on the 1.8t? does anyone else have this problem or had it and knows a fix?
Old Jun 29, 2009 | 05:10 PM
overland04's Avatar
I have found and fixed the problem.
It was a bad timing belt tensioner. The pin that pushes against the wheel failed and the tab attached to the wheel was vibrating against the block. I replaced the tensioner and its quiet again.
Old Jun 29, 2009 | 08:05 PM
Midniteoyl's Avatar
Wow.. sorry I missed this thread earlier. Thanks for comming back to tell us.
Now, how many miles are on the car and did you change the timing belt while you were there? A bad tensioner will add lotsa miles to the wear on the belt.
Old Jun 30, 2009 | 06:28 AM
overland04's Avatar
I have around 150k on the car and the timing belt was done at 114k. I would like to do it again to be on the safe side but in august the car is going to be sitting for a year while I'm out of the country. When I get back I'll be doing a belt and any other fixes I need to do.
Old Jun 30, 2009 | 12:50 PM
pa4ul's Avatar
how hard was that to replace>?
Old Jun 30, 2009 | 01:51 PM
Midniteoyl's Avatar
Good deal..
Rudy G
Jun 21, 2015 11:02 PM
jinsojoo
May 9, 2011 05:49 PM
sunilmsahoo
Jan 25, 2011 02:34 PM
brockley
Aug 10, 2008 12:02 PM
dragondesigns
Feb 14, 2006 01:45 PM
