what should i...
Old Sep 10, 2012 | 05:57 PM
jasemoney999's Avatar
Default what should i...
hey i'm replacing a head on an '02 3.0l motor, while i have everything apart, anything other than vacuum lines i should be replacing? obv t-belt and pulleys waterpump tensioner will be done. but any solenoids that i should check, or gaskets that are out of the ordinary?
basically whats a PITA that i can access now that i should get out of the way (car has 145k)
Old Sep 11, 2012 | 11:57 AM
pa4ul's Avatar
when was the last time u did ur timing belt?
Old Sep 11, 2012 | 02:03 PM
ilackav8's Avatar
valve cover gasket, cam plugs/seals are the usual suspects
Old Sep 12, 2012 | 11:39 AM
Thanks I'll make sure the seals make it on the list. And the timing belt I already have
