My daughter has an 03 A4 Cab 3.0. She just replaced the tires and the guys at Discount Tire said her upper control arms need replacing on all 4 wheels. I don't know if they meant the entire arms or just the bushings. Anyway, other than the dealer, does anyone know a good (inexpensive) place to have this done in the L.A. area (WLA preferred). Or, is the $700 quote by Discount Tire a good deal? BTW, she never complained about squeaking. Is there another way to determine if, in fact, they are bad? They told her the car would be "undrivable" soon if she doesn't get it done.
My suggestion would be to get a second opinion.
Not sure where in L.A. you are, but check out Euro Tech Motors in Culver City.
Euro Tech Motors
(866) 358-1022
11407 Washington Blvd
Culver City, CA 90066
I need to have them change out my timing belt and other small things.
Hope that helps.
Euro Tech Motors
(866) 358-1022
Hope that helps.
- Mechanic needed in Bay Area. Torque converter and engine mounts to be replaced.
- 1998 A6 hit on front driver fender; replaced control arms; still problems
- DIY: B5 Control Arms and Tie Rod End Assemblies, Part 4: Lower Control Arms
- DIY: B5 Control Arms and Tie Rod End Assemblies, Part 3: Upper Control Arms
- Anyone on the bay area? I need to do TB and Cntrl Arms
