White smoke from exhaust while idling
Old May 30, 2013 | 11:28 AM
dan_ben's Avatar
Exclamation White smoke from exhaust while idling
Hi guys i got a 03 a4 1.8t. past couple of days ive been noticing light white smoke coming out of my exhaust also coolent level is going down.. can this be my turbo?? theres no smoke while i drive only when idling..
-thanks
Old May 30, 2013 | 03:28 PM
Nebuchadnezzar's Avatar
This could be a failing head gasket. Anyone else want to chime in?
The white smoke and coolant loss are tell-tale signs of a head gasket issue. Any loss of power?
Old May 30, 2013 | 03:41 PM
dan_ben's Avatar
No the car drives fine. also my fan turns on when i start my car and goes off after it warms up. I just did cyillinder head and head gasket. today my check engine light came on and shows p3081 with no description could that sensor be the problem??
Thanks
Old May 30, 2013 | 05:58 PM
pa4ul's Avatar
hmm i would think it might be ur coolant sensor in the rear of the engine. g62 sensor i think.
Old May 30, 2013 | 06:31 PM
dan_ben's Avatar
But is that causing the smoke?? Thanks for that i will change the sensor tomorrow.
Old May 30, 2013 | 11:43 PM
goldencroft's Avatar
white smoke usually means coolant being burned in the combustion chamber. might wanna get a compression check also.
Old May 31, 2013 | 03:05 AM
dan_ben's Avatar
ok ill report back tomorrow.
thanks
Old May 31, 2013 | 01:01 PM
4ringking's Avatar
If the turbo seal is starting to leak, you can get a little light blue almost white smoke coming out of the tail pipe at start up and it will get worse as the seal continues to fail. The K03s are cooled by coolant and will start to burnt it off when they start to go bad. Head Gaskets usually only fail when you overheat the engine really bad. I have never seen a head gasket "just go" on a 1.8t. I would check your turbo first.
Or the head gasket replacement was not performed correctly...
Old May 31, 2013 | 05:46 PM
pa4ul's Avatar
If your getting white smoke out of the exaust u might have a headgasket going bad. Or like king said u have a bad turbo seal.
Old Jun 4, 2013 | 10:12 PM
djbeanz's Avatar
im also having this issue and i would agree with the coolant leak but i know that coolant smells sweet... as to mine smells very sour almost like clutch burn.. any thoughts??
