| Chito |
Jun 9, 2013 06:22 PM |
an easy test for a bad turbo is to remove the large line connected to the air box to the compressor side of turbo. if there is any play in the compressor wheel then your turbo is shot and the likely source of oil to your exhaust. remove the air box, pull the turbo and have a specialist evaluate the turbo (wheels may be ground and out of balance) and decide to rebuild and/or replace it.
I had nasty smelling white smoke (remember synthetic oil smells different - nasty, not sweet like coolant) coming out my exhaust and was able to repair the A4.
A sludged oil strainer starved the engine (and cooked the turbo). after replacing the oil strainer, turbo, oil feed lines.. etc., the smoke cleared the exhaust after driving for 15 minutes.
Car now runs fine (OK, the car historically blows coils in the number #2 cyl., but that's a symptom caused by a separate problem I trying to identify). Good luck!
