2007 Audi A4 2.0T Heavy smoke and loss of coolant
Old Aug 29, 2022 | 02:15 PM
ZomBot1252's Avatar
Default 2007 Audi A4 2.0T Heavy smoke and loss of coolant
When the car is idling it spits heavy white smoke and you can see coolant draining down but there's no leaks anywhere not under the car or behind the engine, no where at all, it also makes this misfire bubbling sound on the turbo side, and when I accelerate smoke gets worse, after car running for about 20 mins starts choking, when I add coolant it gets worse, I already did head cover gasket, no leaks , also engine got alot loader from the cam chain area on the back, I'm stuck and don't know what else to do at this point.
I've read in other posts that it could be turbo coolant seals bad but it's loosing coolant way too fast for a bad seal, or am I wrong?
Please help in new in Audi world so I'm still learning.
I will take a video and pictures and will post it later today after work
Old Aug 29, 2022 | 02:19 PM
ZomBot1252's Avatar
Also car doesn't stay on for longer then. 30-45 min with coolant in it, and doesn't overheat either, all I have is 1 code P0089
Old May 21, 2023 | 09:34 PM
philipwk's Avatar
So what did you fix to be rid of this P0089 code?
camarochris
Feb 2, 2022 08:52 PM
audinoob27
Mar 27, 2012 11:31 AM
Bklynrx7
May 27, 2011 01:03 PM
Genix
Jan 8, 2007 02:06 PM
CaliA4
Dec 28, 2004 12:12 AM
