Audi A4 2.0T Quattro 2006
Old Jul 20, 2017 | 02:15 AM
Rich Bezus's Avatar
Default Audi A4 2.0T Quattro 2006
Hi, I have a 2006 Audi and for some reason I have oil everywhere in my engine. It's spilling not from the oil pan but from the top of the engine where my spark plugs are. My spark plugs are flooded with oil and my check engine light is on. When I start the car (or leave in park) my rpm's are at 800 and the car starts to shake as if it's about to shut down. I don't know what is wrong with it and where could the oil be leaking from. But, the spark plugs underneath my black engine cover are filled with oil and oil keeps coming out. Any idea what is wrong? Thanks
Old Jul 21, 2017 | 02:14 PM
KingWulfgar's Avatar
Clean it all off and find out where it's really coming from. Sounds like it could be your valve cover gasket (a fairly easy and inexpensive fix). PCV can also be an issue with these cars (there was a recall a while back) as well as the valve cover itself could be cracked.
Start with a cleaning and some more investigation and then probably the valve cover gasket. Mine was hard as a rock, stuck on good, and super brittle and crumbly after nearly 11 years and 100k miles.
Old Jul 23, 2017 | 08:07 PM
rhodes991's Avatar
PVC cleared up a lot of my oil sitting around the spark plug. I recently replaced the valve cover and it is clean now.
DPapworth33
May 1, 2014 12:45 PM
jattsingh
Nov 5, 2009 02:25 AM
Redryder
May 17, 2006 03:32 PM
ld757
Nov 30, 2005 08:05 PM
sark
Nov 1, 2005 08:42 PM
