Blow off valve
Old Nov 21, 2009 | 05:39 PM
jhlax57's Avatar
Default Blow off valve
http://www.esetuning.com/Forge-Motor...t-polished.htm
Really love the sound of a blow off valve but will this harm my turbo or car at all. Heard people that say the blow off valve hurts their car but is this ok for my car. I have an 08 a4 s-line. Thanks for the help
Old Nov 21, 2009 | 11:09 PM
RedA4RedCalipers's Avatar
Dude you absolutely dont want blow off valve on your car. Trust me
Old Nov 21, 2009 | 11:13 PM
Old Nov 22, 2009 | 03:42 PM
jhlax57's Avatar
so should i get a forge diverter valve instead?
Old Nov 22, 2009 | 07:28 PM
eMacPaul's Avatar
Or keep what you've got. I'm running the stock DV and I've been chipped for 10k miles now.
Old Nov 22, 2009 | 10:08 PM
Yes. Forge makes a spacer that makes the woosh sound that me and you like so much but still uses a Diverter Valve
Old Nov 24, 2009 | 10:11 PM
2wdBlazer's Avatar
That was the spacer he posted.
http://www.forgemotorsport.com/conte...roduct=FMDV14T
This is the one you want because it is compatible with the D valve. That is the valve that won't break like the diaphram valves. If you get the wrong spacer it won't fit the D valve. Be warned, these spacers are loud as hell.
Won't hurt you though.
Old Nov 25, 2009 | 06:17 PM
jhlax57's Avatar
http://www.forgemotorsport.com/conte...roduct=FMFSITV
So is this the diverter valve i want then? Is it ok with the optional blow off valve spacer?
Old Nov 25, 2009 | 11:22 PM
2wdBlazer's Avatar
No. The best valve is the OEM "D" Valve. It is a piston design that takes the place of the Diaphram design. More responsive and best of all it's the cheapest. http://www.ecstuning.com/Volkswagen-...alve/ES263879/
It you did not know, all the aftermarket valves require them to be opened up and maintained. Not worth it and no better performance. You must use the spacer I listed if you use the "D" OEM valve.
Old Feb 3, 2010 | 01:24 AM
ahl2001's Avatar
Hello, I've just purchased my first Audi and my first ever turbo car. Just picked up a 2003 Audi A4 1.8T and would also like to hear the turbo sound. From reading this thread I've decided to go with purchasing the OEM "D" valve along with the forge spacer. You mentioned the oem D valve doesn't require maintenance...does the forge spacer require periodic cleaning? If I were only to purchase the d valve OR jsut the spacer would i hear the equivalent of the BOV sound? does adding both increase the sound? additionally, i'm thinking about chipping the car as i read that that gives u the most bang for your buck. however, i've read that if you were to chip it you should upgrade the diverter valve. would this oem D valve suffice as an upgrade if i were to chip it...or would i have to purchase another one? thank you so much for all the info provided!!
