boost fluxing problem
Old Jul 31, 2010 | 04:50 PM
sta4q20t06's Avatar
Default boost fluxing problem
i have a 2006 audi a4 quattro 2.0T b7 body with 128,000 miles. mods are apr stage 2+ tune, downpipe, forge dv, awe front mount intercooler, newmotor boost gauge. the other night i was driving my car and in third gear at high rpms my boost would fluctuate i usually hold about 20psi and i was only getting 15 down to 10 back up to 15 back down to 10 . im not sure what the problem is but im very worried, if you have any ideas please let me know.
Old Aug 1, 2010 | 01:15 AM
makav3li's Avatar
You get a CEL (check engine light)? even if you don't, see if you can get your hands on a vag-com or if u cant, go to autozone and get your car scanned to see if any codes pop out. I'd trace your boost lines to check for cracked/loose clamps, specifically your boost gauge tap, that could deff be the culprit.
Old Aug 1, 2010 | 11:56 PM
dmfan016's Avatar
its your hpfp going stage 2 + u will see fuel cuts that would drop your boost as well
Old Aug 3, 2010 | 12:27 AM
sta4q20t06's Avatar
well , the other day it was fluxing as i stated previously, and now in second gear it over boost hits 23 , and then it hit 24 and went into lymp mode , i heard it could be my n75 valve ? i dont have a cel, and i went to autozone , nothing .. my friend has vagcom im tryng to meet up with him . but i also heard that it could be my fuel filter , not pump. but the fuel pump is only 4 months old i dont get it
audia4boy24
Jul 26, 2008 11:03 PM
dgirlsdemsugar
Jul 21, 2007 09:28 PM
eurotech
Apr 5, 2006 02:18 AM
Dieselboywu
Jul 24, 2005 02:11 PM
active1331
May 23, 2005 09:15 PM
