Coolant Leak
Old Jan 9, 2009 | 08:08 PM
speedtrpl's Avatar
Default Coolant Leak
Just joined 2 minutes ago! Looking for some help with an '07 A4 Convertible. Noticed a leak in the garage last week. Coolant level in the overflow reservoir is below min. With a flashlight I can see coolant on various surfaces but the only "leak" I can identify looks like it's coming from what I can best describe as a bleeder valve on the very top hose running front to back over the engine. The top broke off somehow...maybe a sloppy technician during an oil change because it's under the plastic engine cover?
I couldn't identify what part # it is in any diagrams, or if it could be easily replaced. Not even sure how to get the bottom half out which is still threaded in there? Anyone know what this is and if it is a bleeder valve that can easily be replaced?
Old Jan 9, 2009 | 08:18 PM
AWDTURBO's Avatar
Try to see if you could blame it on Audi, so everything has to be replaced by them for free.
If not, then im not sure.
The thread is stuck inside still? If so, i have watched videos on Youtube, on how to remove broken bolts and it actually works. Even though you speaking about plastic see how it works. Give it a try.
Old Jan 11, 2009 | 12:00 AM
eMacPaul's Avatar
I'd call AudiCare and have them tow it (they'll flat bed it) to get it repaired. Assuming it doesn't look like you were screwing around and broke something yourself, they should take care of it.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
