Engine Squeak and Battery Light
Old Dec 1, 2011 | 12:20 AM
wainakh's Avatar
Default Engine Squeak and Battery Light
I've got a 2006 Audi A4 2.0t with 58k miles on it. The battery light came on 4 days ago and I took it to the dealership and got the battery replaced and a back brake light fixed. Light went out and today I got in the car and as I was driving, the battery light came on again. This time however, I noticed that the engine started squeaking as the light came on (due to the open window). I noticed throughout the day that sometimes when I turn the car on, the squeaking starts right away and the battery light turns on. Sometimes, it'll be a minute before the light turns on with the accompanying squeaking. It seems as if the squeaking gets worse with engine speed but it wasn't easy for me to determine how accurate that impression was. Any ideas whats wrong?
Old Dec 1, 2011 | 11:01 AM
rhodes991's Avatar
Did the dealer confirm the alternator was working before they replaced the battery? That could be your issue.
Old Dec 1, 2011 | 03:30 PM
esandes's Avatar
Banned
is the squeal from the loose serpentine belt? maybe it's so loose it's not spinning the alternator. is it difficult to turn the steering wheel while you're at a stop? the power steering pump is in that belt loop too.
Old Dec 2, 2011 | 02:34 PM
2wdBlazer's Avatar
Definately a bad ALT or loose belt.
Old Dec 2, 2011 | 06:50 PM
wainakh's Avatar
That's what I had in mind but didn't mention anything when I called the dealership. I haven't had a chance to take it in yet but talked to the service department on the phone. They think it may be a crankshaft valve and had no idea why the battery light was on. Didn't think there is an issue with driving it. They never said anything about the alternator, just that they did a test after replacing the battery and found a little bit of extra draw on the battery but that was it. Is there any way I could try identifying where the squeak is coming from in the engine compartment? The steering wheel hasn't been noticeably harder to turn.
Old Dec 5, 2011 | 05:34 PM
wainakh's Avatar
Turned out to be the alternator pulley locking up. You guys know where I can get more info on that?
Old Dec 5, 2011 | 07:17 PM
rhodes991's Avatar
Did they say what is causing the pulley to lock up? I would guess that the alternator is faulty (which is causing the pulley to lock up). Although pulleys can be replaced I would think the whole alternator needs to be replaced.
Old Dec 6, 2011 | 04:22 PM
Audi Tek's Avatar
Tech Certified
They are blowing smoke up your ***.... Some unexperienced tech forget to check the Alt before selling the battery.
The battery light has nothing to do with the battery
The battery light has a wire called an exciter wire that comes directly from the alternator. It only comes on when there is a problem with the charging system
AudiVeight
Jun 8, 2016 07:23 AM
blu.suede
S4
Apr 21, 2015 12:38 PM
disneyfann
Nov 12, 2013 03:16 PM
wainakh
Apr 26, 2012 09:01 AM
pec2402
Jan 23, 2007 01:35 AM
