Ghost Fuel problem with an audi A4 b7 2.0t quattro
Hi everyone,
After a cylinder head rebuild the car dies while driving....
Most of the times the car dies after a 10 min drive.
i have a vcds and throwing these codes.... P310B...P0087 and the car dies.
The car will not start again... and will start again only if i release the low fuel pressure line
Here is the worst...i've change everything related with the fuel system
New LPFP
New HPFP
NEW FILTER
NEW CAM FOLLOWER
NEW Fuel controller module
New Fuel pressure regulator
New G410 SENSOR
New High pressure fuel sensor.
I have also changed cam sensor and the crank sensor.
I don't know what to do next with this car and i was wondering if someone could help me or have similar issues in the past.
My next move is to change the ecu, what you guys think?
Also when the car dies automatically i can see through vcds that the Low fuel pressure drops to 2.0 bar and the the High pressure also drops to 5 bar.
i've used an external gauge to measure the low fuel pressure line and looks ok when the car dies and the G410 sensor shows 2 bar the gauge shows 6bar.
Please leave comments and let me know if you had similar issues?
Thanks.
Dim.
.Here is the worst...i've change everything related with the fuel system
New LPFP
New HPFP
NEW FILTER
NEW CAM FOLLOWER
New G410 SENSOR
Thanks.
Dim.
c_sweet2006
Feb 28, 2010 06:56 PM
