Head Unit swap...scratching head...factory amp issue
Old Aug 8, 2015 | 03:26 PM
Trigger200's Avatar
Default Head Unit swap...scratching head...factory amp issue
Installed a new Kenwood head unit into my otherwise stock 07 A4 (non-bose, symphony).
Anyways, used the PAC harness and everything seems to be working just fine; however, the rear door speakers and amp just don't have the same volume as the stock radio. The read doors speakers and sub are getting audio signal but they aren't as loud as the front speakers. I would expect them to be louder considering it has the factory amp. I tripe-checked the new wiring harness and I am certain there is 12+ vdc going back to the amp for turn-on (white wire in dock n lock connector).
What has me scratching my head is that the dock-n-lock connector is populated with RCA connection points but it makes no difference if I have the Front/Rear RCAs plugged into my Kenwood head unit. I also noticed that the dock-n-lock connector is NOT populated with speaker wires for the rear left/right so I have no idea how the rears are getting an audio signal and why the volume is low.
Any help would be appreciated!
Old Aug 16, 2015 | 09:35 PM
imaudi5000's Avatar
i have no clue, but i would check with the technicians at crutchfield.com
idk if you can get much help without buying something, but worth a shot. they know a ton of stuff
NEP
May 3, 2008 03:49 PM
Mininger
Mar 10, 2008 10:30 AM
dmuse
Dec 18, 2007 03:01 AM
A1C Basinger
Jun 12, 2007 09:53 AM
1999 Audi A6
Oct 6, 2006 05:59 PM
