Help misfire!!
Old Mar 22, 2015 | 01:50 AM
Breino64's Avatar
Default Help misfire!!
Hello I am new to this forum but have been getting info for some time now from here
My problem is after taking my car to the dealer for the cam, can follower , and hpfp my car has a misfire in cylinder 3. The dealer said it was the injector. I replaced the injector, spark plugs, tested the coil, and clean out the carbon from all the cylinders. I have no idea what it could be and I really don't want to take it back to the dealer because everytime I get it back from there something else gets broken... Any Ideas? And my car was running fine before I took it in no check engine light or misfire before...
Old Mar 22, 2015 | 06:38 PM
KingWulfgar's Avatar
Coil pack? Not terribly expensive to try it and see if it fixes it.
Old Mar 22, 2015 | 08:02 PM
Breino64's Avatar
Na I already did the coils and spark plugs :/
Old Mar 23, 2015 | 03:10 PM
Well, you only said you tested it. Have you tried just resetting the code and see if it comes back? You could also swap stuff to a different cylinder and see if the code moves.
Old Mar 24, 2015 | 12:17 AM
Breino64's Avatar
Yea I reset it moved plugs and coils around and still get the misfire in the same cylinder
Old Mar 24, 2015 | 10:58 AM
Sorry, bud. I'm out then. It's possible the new injector is bad or you have deeper (and more expensive) problems with that cylinder. I'd be taking it in at this point as I don't dig deeper than the "easy" stuff. Sorry!
Old Mar 26, 2015 | 08:51 PM
Breino64's Avatar
So I took my car to the dealer and there saying that I have to put my car back to stock... Even though I dropped my car off with no codes or cel so I'm just going to park my car untill I can save up some money to take it to a shop...
Old Mar 27, 2015 | 01:23 PM
mhoward's Avatar
Put your car back to stock? tell us what you've done to it, that might help.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
