How do I program my garage door opener?
Old 07-24-2008, 11:17 PM
ggracing_A4's Avatar
Default How do I program my garage door opener?
I have a 2006 Audi A4 and dont have the manuel. Anyone know how?
Old 07-24-2008, 11:26 PM
b7a4/07busa's Avatar
Default RE: How do I program my garage door opener?
Hold in the button of the trigger you want to use on the visor until it lights up and stays on. There is a sensor on the front driver side. Point and activate your garage door opener a couple feet from the sensor. It clones the signal. Check it to see if it worked, it should. If not, try again.
Old 07-24-2008, 11:51 PM
harryd14's Avatar
i think you might have to hold the button or press it at the same time while your pressing the button at the sensor on the front drivers side of the bumper between the lights and grill... but i could be mistaken
Old 07-25-2008, 12:15 AM
eMacPaul's Avatar
I think I had to hold the two outside buttons for about 30 seconds to activate programming mode, and then once you've pressed the button you want to program you've got either 30 or 60 seconds.
Old 07-25-2008, 02:14 AM
dmfan016's Avatar
do you have a rolling garage code or a standard code that never changes theres two different processes....PM me about it
Old 07-25-2008, 02:57 PM
correction to what I posted earlier. i wasnt 100% sure so i checked my manual. push and hold I&III until the l.e.d. flashes after about 20 secs. pick the channel u wanna use and press it for about 5 secs and the indicator l.e.d. will flash slower. u now have 5 min to clone the signal. use the garage door opener about 1 foot from the sensor under the driver side headlight. push and hold. once signal is copied, the flashers on the car will flash 3 times. u can then release the button on the opener. it takes anywhere up to a min. good luck
Old 07-28-2008, 08:04 PM
tried it.... the flashers flashed 3 times telling me it got copied but i didnt work. When i pushed the button to open the garage it didnt open
Any other suggestions?
Old 07-29-2008, 04:18 PM
eMacPaul's Avatar
Some garages require you to also program the receiver to accept the new remote. If so, there should be a button somewhere on the garage unit to press, and then you'll press (and hold for a bit) the button on your car. You may need to press it a couple times for the garage receiver to learn it.
Old 07-31-2008, 09:45 AM
esandes's Avatar
Banned
be sure to hit the learn button on the garage door opener.
Old 09-02-2008, 01:36 AM
samfoster's Avatar
Hi,
I would suggest to get another manuel.
So it will be easy for you to program garage door opener.
__________________
Sam Foster
Leeds, UK
Garage Doors Leeds
abrearton
03-04-2014 09:53 PM
gate.tann
10-31-2013 06:53 AM
esandes
06-27-2010 12:58 PM
VeGaS
01-31-2006 03:33 PM
Quick Reply: How do I program my garage door opener?
