ignition noise during cold start
Old Mar 28, 2014 | 07:58 AM
Aspire Invest's Avatar
Default ignition noise during cold start
my A4 makes a rough 5 second noise just after ignition especially in the morning and after parking for over 1 hour what is it please help
Old Mar 28, 2014 | 09:32 AM
rhodes991's Avatar
Really need a more information to provide help. I am guessing here, but if you are saying the car runs rough for about 5 seconds then I would ask if when you start the car do you insert the key and turn the ignition quicky to get it cranking? The reason I ask is when you turn the key it starts the fuel pump and if you quickly turn the key the fuel system may not be fully pressurized when you start the car. Try turing the car on and then wait a few seconds before trying to start it. See if that helps.
Old Mar 29, 2014 | 01:20 PM
hi thanks for the response. tried that but no good. when i turn the ignition 1st second okay from 2 to 5 is the noise then it disappears my mechanic thinks is the chain tensioner that is worn out. any suggestions.
Thanks
Old Mar 30, 2014 | 10:22 AM
rhodes991's Avatar
Have you confirmed the noise is coming from under the hood of the car? When you turn the key you should here noise for a few seconds as the fuel pump primes the system. that noise would come from just to the drivers left side. If it was the tensioner I wouldn't think it would go away after a few seconds. Best bet is to take it to a good mechanic that works on Audis.
Old Mar 31, 2014 | 09:48 AM
am un able to upload a short video of the engine and the sound can i send you by email?
Avant Fan
B8 Models
13
Nov 13, 2014 02:33 AM
muzhao
B7 Models
10
Feb 24, 2013 10:53 AM
1SIKA4
Nov 19, 2010 02:32 PM
beefski
Nov 25, 2005 04:51 PM
Meradin
Oct 15, 2005 07:30 PM
