misfiring cylinder 1 issue...P0301
Old Apr 2, 2011 | 02:34 AM
2wdBlazer's Avatar
I have never seen a D valve fail. I would go over the BSH hardware and pull it off and reinstall to make sure it's seated. You could have a shop pressure test the system. Look for unhooked hoses around the PCV or boost tap if you have a boost gauge.
Old Apr 8, 2011 | 12:24 AM
theunknownprince's Avatar
im doing the pressure test tomorrow let hope its a simple fix. by the way i heard cruise control is controlled by the vacuum... so if its a leak then its should work right? but my cruise control does work..... heading toward fuel injectors now......
Old Apr 11, 2011 | 08:37 PM
lol youre right 2wdBlazer!!! i did a boost leak test using the the tennis ball trick and i found it. Turn out my PCV breather hose is leaking. now the real problem is removing the hose and replacing it with a new one. any suggestion on removing this.....http://www.ecstuning.com/Audi-B7_A4-...alve/ES281099/
Old Apr 12, 2011 | 07:56 AM
Xarpolis's Avatar
Any chance your car is still under warranty? If so, your problem is as good as fixed (for a small $85 fee to you). That should include the new part as well.
It's worth looking in to.
Old Apr 12, 2011 | 03:28 PM
2wdBlazer's Avatar
I told you! Not sure on what the problem is? It should be simple to replace.
Old Apr 13, 2011 | 01:58 AM
no its not the lower pcv valve hose cost me about 50 bucks. my main concern is how can i get the the other end under the intake manifold ... might have to remove the throttle body....any suggestion?
Old Apr 13, 2011 | 04:36 PM
2wdBlazer's Avatar
If you are tight on space snap it off with a scredriver or cut it off. The new one should just pop on or clip on. Does it look like a self clicking connector? You should not have to pull the TB or anything major.
Old Apr 16, 2011 | 10:39 PM
  #18
I have replaced the hose. I test drove the A4 and saw it boosting at 19psi (torque apps for android) ten minute later....hesitation occur then MIL came up.
so since that same day I received my vegcom. i plugged it up and found this=
2 Faults Found
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 3
Mileage: 118753 km
Time Indication: 0
Freeze Frame
RPM: 2837 /min
Load: 66.2 %
Speed: 60.0 km/h
Temperature: 93.0∞C
Temperature: 43.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
000769 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame
Fault Priority: 0
Fault Frequency: 3
Mileage: 118753 km
Time Indication: 0
Freeze Frame
RPM: 2837 /min
Load: 66.2 %
Speed: 60.0 km/h
Temperature: 93.0∞C
Temperature: 43.0∞C
Voltage: 13.589 V
and also this
1 Fault Found
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 31
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x0024
Hex Value: 0x0194
Hex Value: 0x0001
any idea?
Old Apr 12, 2012 | 08:00 PM
  #19
7nawakeup's Avatar
I am having the exact same issue...did you ever figure out what it was??
Old Apr 13, 2012 | 10:54 AM
  #20
Xarpolis's Avatar
I had my car in to the dealer the other day for a scheduled oil change. While there, they also did some recall work (changing a valve flap). Apparently it's not a publicized recall. They're only doing the update if you already have your vehicle in for something else.
May be worth calling them to ask about it.
