Motor Mounts
Old Nov 9, 2013 | 05:56 PM
ghughes3.gh's Avatar
I finaly got new motor mounts in and had time to install them helped a lot both mount were broken. both mounts the rubber was busted. the car still has what feels like a misfire but is not giving any code expect headlight out which is another strange thing it works sometimes going to take the car in to a friends shop he has a nice code reader
Old Nov 10, 2013 | 12:42 PM
B7Night's Avatar
Have you had your coils checked? The coils that Audi/VW use have had a tendency to fail. Also, another thing that could be causing what feels like a misfire, is carbon buildup. Certain years of V6 and V8 Audi engines have had issues with carbon buildup, which can cause a misfire situation. Since these are direct injection engines, not a drop of detergent ladden fuel touches the intake valves or runners, causing oily PCV valve gases to build up on those parts causing issues. For some reason, you don't seem to hear about it as much on the DI Turbo 4. Interestingly, one of Audi/VW's solutions to help keep carbon buildup at bay is to run the engine at 3000rpm or more for 20 minutes. It helps to burn off the carbon buildup. No joke, it's actually mentioned in the Audi/VW patent paperwork on the DI engine. It's otherwise known as an Italian tuneup. So you might want to take the car out somewhere and drive the snot out of it for a little while, especially if your typically very easy or gentle with the car and throttle or do lots of short city trips.
Old Nov 11, 2013 | 01:13 PM
thanks for your help ive been leaning towards the coils myself im hoping that the coil could be the problem
Old Nov 11, 2013 | 09:18 PM
B7Night's Avatar
Several years of the coils on the 2.0t got replaced free in a service action due to the high rate of failure. You might want to check and see if your V6 was included in that service action.
Nemick
Sep 17, 2012 06:34 PM
murdox
Aug 24, 2011 10:06 AM
guru_king423
Apr 7, 2009 10:48 PM
SouthernAudi
Feb 9, 2008 07:48 PM
jimmyt853
Jan 12, 2007 02:22 AM
