New brake pads and rotors @ 29K?
my brakes have started to squeal pretty loudly recently. i got a 2008 2.0TQ and just reached 20k miles. the front brakes make the rims super dirty so im assuming they are soft pads like others said and should be replaced soon. i live up near syracuse NY now and was wondering if anyone had any recommendations on brake pads or places to get them replaced.
Reason the pads wear so much,,,too much metalic in the pads,go to tire rack .com & buy some pro stop ceramic pads,,,rotors will last longer,soft pads do not wear out the rotors. It's the high metalic content.
Care to share the trick? The wifes car needs brakes and no way in h$ll and am I paying the dealer. I have heard that the fronts are straight forward, but the rears need a tool? Thanks much!
Yeah, I found the tool at Harbor Frieght for $25. It would be dumb to try it without it. I also read that it is pretty common to change the rotors with low mileage. The wifey's car only has 60000 miles, but I am thinking no way should the rotors need to be changed.
the carpenters C-clamp works on rear brakes too.
What is good idea is to open the bleeder and push the fluid out while pushing the piston. Brake cylinders are the area where most contamination happens and it is better not take the chances to push the stuff back into ABS pump and master cylinder. This way you have good start for brake bleeding as well.
I just bought set of rotors and pads from Canadian dealer on ebay. Whole thing about $200 delivered with galvanized rotors. Stuff made in China, but that shouldn't matter for rotors. Pads works well as well.
Anyone knows the recommended pressure for power bleeding?
