oil pressure message
Old Oct 23, 2014 | 08:44 PM
Rcbama's Avatar
Default oil pressure message
got a low oil pressure message and after driving a while longer started idling rough then check engine light came on got po300 po301 po302 po303 po304 codes,replaced plugs with ngk factory original still idling rough
Old Oct 24, 2014 | 01:41 PM
mhoward's Avatar
need a little more info here...what engine, year, have you checked your oil? did you change spark plugs? change your coil packs? any engine sounds? probably should of stopped driving it you got the oil light, that usually means you've lost pressure or you're low on oil and need to add more. I'm thinking coil packs are your misfire problem 90% of the time it is on these cars.
pdxrado
Jan 28, 2013 06:35 PM
Dallas09
Aug 30, 2011 05:57 PM
charcormier
Mar 27, 2007 03:40 AM
rustyleskiv
Apr 11, 2006 01:15 AM
