P0089 code gone!
Old May 22, 2018 | 04:49 PM
Hgk2's Avatar
Default P0089 code gone!
I thought I would post this, since I know so many of us have this issue. I had the P0089 fuel code coming on and off for a long time. No driving issues, just the annoying code, which woud come on and off on a daily basis. As others, I tried replacing the fuel filter and pulled the hpfp and replaced the cam follower. I did not replace the pump, just the follower. After about 78,000 miles it was preventative maintenance and surprisingly it wasn't bad. Anyway, this did nothing to fix the P0089 code. I figured since the car drove fine, that I could live with the intermittent check engine light (more on than off). I just went about checking the codes every so often to make sure no new code(s) were thrown. Fast forward- I recently had the car in the shop at 84,000 miles to replace the coolant flange due to a loss of coolant coming from the back of the motor. I purchased the ECS kit which comes with a new temp sensor. Well, it has now been almost 800 miles and a few weeks (I took a 400 mile trip out of state) and no P0089 code. I don't know if it had something to do with the temp sensor, but that is the only electrical piece that was replaced. I will post an update in a few thousand miles if still no code, or if it comes back. I know people have tried everything and not been able to solve this code, and it makes no sense to me that a coolant sensor would fix the code, but I won't complain.
Old Sep 18, 2018 | 06:11 PM
Hgk2's Avatar
Update- Its now been 4 months and about 4,000 miles since my last post and I am happy to say that the code has not returned. If I just jinxed myself I will post another update if the P0089 code returns. If it stays off, I will not update, but you will know how long changing the temp sensor has worked to date. Hope this helps someone else with the P0089 code.
montanakid@frontier.com
Apr 1, 2015 10:50 PM
Vannylasky
Jan 29, 2013 05:11 PM
h4x0r
Nov 17, 2010 01:13 PM
pstyle
Mar 1, 2010 11:55 AM
tbr76
Jan 17, 2009 03:37 PM
