PLEASE HELP Cold Start Noise
Old May 16, 2011 | 12:31 PM
muzhao's Avatar
Angry PLEASE HELP Cold Start Noise
i've got a 2.ot quattro 2007. it seems making a strange noise when i start the car in the morning, like a squeaky fan noise from the engine somewhere its not the ticking noise im on about i no thats do to with the high pressure fuel pump. but it will go after its wormed up.
can anyone Help
Many Thanks
Old May 16, 2011 | 02:06 PM
Torsion'sA8's Avatar
Default Just had it fixed
Turned out to be the water pump.
Old May 16, 2011 | 11:28 PM
esandes's Avatar
Banned
i had a cyclic squeak noise coming from one of the pulleys and when the engine got warmed up it would go away. i ignored it for 3 years and finally had enough and brought it to the dealer. they noticed it too and they said the belt tensioner needed to be replaced. it's been perfect ever since. they did end up changing the timing belt and all of the pulleys at the same time. so good deal.
take it to the dealership and have them check it after a cold start up.
Old May 17, 2011 | 04:08 AM
muzhao's Avatar
Thanks guys turn out to be one of the pulley so I'm gonna wait till when the belts goes and then get it changed then was it expensive from the main dealer???
Old May 18, 2011 | 11:55 AM
rrodri05's Avatar
how much did it cost you at the dealership?
Old May 18, 2011 | 11:23 PM
esandes's Avatar
Banned
it was all free. it was covered under warranty. all they had to do was change the idler pulley or something but they ended up changing all the pulleys plus the timing belt.
Old Jun 14, 2011 | 01:38 PM
muzhao's Avatar
@esandes but my car is not under warranty anymore
Old Jun 17, 2011 | 06:12 PM
esandes's Avatar
Banned
how long has it been happening? it's likely the tensioner so just have the mechanic change that and the timing belt. the belt is probably due soon if it hasn't been done already. you need to change the belt at 100,000 km intervals.
Old Jun 17, 2011 | 06:15 PM
esandes's Avatar
Banned
that's the dumbest idea i've heard in a long time. how old are you? do they just give audi's out at the slum shelters?
Old Jul 5, 2011 | 04:46 PM
Praetorian's Avatar
I just talke to the audi service dept and was told that the noise is caused by the air pump pumping air in the cylinder head.
