possible vacuum problem or a leak
Old Nov 27, 2011 | 08:32 PM
redcar's Avatar
Default possible vacuum problem or a leak
my audi started making whistling sounds when it heats up all the way and i dont know where it is coming from, when i disconnect the vacuum hose from the brake booster while the car is running the squicking stops and when i pull out the dipstick the vacuum is really strong and pulls it back into the engine and when i try to open the oil cap on the engine it is almost impossible to open it and when you pull it off the engine with alot of force, it stalls
do anyone know why its doing that or what is wrong?
maybe some diagrams or pictures please
i found a video on youtube but it is a 1.8t and i dont know if its the same
Audi A4 1.8T with excessive vacuum running through breather system - YouTube
thanks alot ahead of time
Old Nov 27, 2011 | 09:40 PM
rhodes991's Avatar
Sounds like the PCV has failed. About $80 for one and easy to change.
Old Nov 28, 2011 | 03:00 AM
redcar's Avatar
thanks
is there any way to see where it is located and any way to test it?
Old Nov 28, 2011 | 09:10 AM
rhodes991's Avatar
If you have the 2.0T it is on the driver's side of the engine at the top. Looks like this:
Audi B7 A4 Quattro 2.0T > Search > Breather > ES#11561 ECS Breather Update Kit - 06F198206
Old Nov 28, 2011 | 09:20 AM
Toasted Coastie's Avatar
Get this instead. Cheaper and bullet proof.
BSH 2.0T FSI PCV Revamp - BSH Speedshop
See sticky:
https://www.audiforums.com/forum/b7-...sticky-144534/
Old Nov 28, 2011 | 11:07 AM
redcar's Avatar
thanks a lot guys, i will try to get one today
Old Dec 4, 2011 | 08:30 PM
westhive4life's Avatar
I opened the oil cap while my engine was running last night and it sounded like it was about to stall so I quickly put it back on. Ordered my bsh pcv this morning. Hopefully it solves my problem too
Old Jun 21, 2018 | 02:08 PM
Aran Kaspar's Avatar
Default Did the BSH work well?
What ever happened here guys? Anyone have an update?
Old Jun 21, 2018 | 02:50 PM
rhodes991's Avatar
On my car it fixed the issue.
Old Jun 21, 2018 | 06:11 PM
Should I install a catch can?
cowabungaman
May 15, 2014 04:28 PM
Nemick
Sep 7, 2012 09:59 AM
flyromeo3
Jan 27, 2009 05:24 PM
quattro/2.8
May 13, 2007 02:13 AM
AndyChild
Feb 8, 2006 01:39 AM
