Problem with silverstar ultra light bulbs
Old Jan 19, 2009 | 10:48 PM
jc32002's Avatar
Default Problem with silverstar ultra light bulbs
I just put in the silverstar ultra vision light bulbs in my car tonight, and was really happy with how bright the light is. However, when I went out on a drive, i felt like I was highbeaming everyone with the driver side light. Has anyone else have a similar issue? Any suggestions? The lights are great on desolate roads, but around the city I feel like its really annoying and I'm thinking about putting the original bulbs back in.
Old Jan 20, 2009 | 11:19 AM
dmfan016's Avatar
the headlight angles are probobly off....you can fine tune the horizon of a light bulb and tailor it...it just takes a while
Old Jan 21, 2009 | 08:33 AM
jc32002's Avatar
Thanks. Anyone know how to adjust the headlight angles and the horizon of the bulb? I used to have a chevy truck that just had a set of screws to adjust and it was easy...german cars not so much
Old Jan 22, 2009 | 12:11 PM
RacerXXL's Avatar
The Audi has the same thing basically - just a little more complicated. Look for the adjustment screws near the rear of the headlight assembly. It's been a while since I did mine - but I think they have covers.
Old Feb 6, 2009 | 02:32 AM
JDS1985_B7's Avatar
No way! Cause my lights are angled so low you can see on the road where the light ends and darkness begins... ( seems low to me ) im used to driving a lifted jeep with 33's.
Old Mar 17, 2009 | 08:11 AM
knerml's Avatar
Member
The reason your light act like high beams is because you do not have the new bulbs inserted properly.
If the bulb in not located in the proper position, the light pattern will be wrong.
Make sure that the tab on the bulb's base is pointing upward and seated in the notch in the headlight housing, and that the bulb is fully seated.
I use an inspection mirror to check the bulb, to make sure it is mounted properly.
Audi Forums Editor
Apr 25, 2013 11:38 AM
numlock4045
Feb 9, 2011 07:12 AM
Tourbo24
Aug 20, 2010 06:58 PM
generik777
Jun 6, 2008 10:36 PM
ryandlor
Oct 22, 2007 01:07 PM
