Removing instrument cluster
Old Nov 27, 2011 | 01:59 PM
newsrus's Avatar
Default Removing instrument cluster
I plan to replace my MPH speedometer dial with a KPH dial. To do that, I need to remove the instrument cluster. I can't find any instructions on how to manage that on my 2007 A4 cabriolet. There are instructions relating to other A4 models, but the cabriolet trim is slightly different. i can pop off the outer trim but there are no obvious screws or clips holding the cluster in place. Any help would be greatly appreciated.
Old Nov 27, 2011 | 09:43 PM
rhodes991's Avatar
I have seen some write ups about adding the RNSE and you have to drop the steering wheel down to it's lowest setting and remove the trim there exposing two torx screws if I remember correctly. Then you pull the left side out first disconnecting the connectors on that side and then pull it our further to get to the other side.
ImSoSkrood
Jan 11, 2015 09:48 PM
Yuyo1977
B8 Models
Nov 12, 2012 05:37 PM
jhanson25
Jul 20, 2010 09:41 PM
asutherland
Jan 22, 2010 09:58 AM
Mitoska
Sep 30, 2007 11:05 PM
