sunshade won't open or close with sunroof 07 A4
Old Jun 30, 2011 | 03:52 PM
Jerry Bodine's Avatar
Default sunshade won't open or close with sunroof 07 A4
While searching the forums I found out that this is a common problem. apparently a couple of plastic clips break and the sunshade moves freely, but when opening or closing the sunroof it will not move the sunshade. Is this a very time consuming repair? If this happens a lot I don't want to go to the dealer every time it breaks. I read that I must remove some plastic trim piece, not sure which one. Then remove the side bellows and remove 4 torx screws and remove the glass from the outside. Is this the right procedure and does anybody have pictures. With the new parts in hand will the repair be self-evident??
Thank You for any information.
Old Jun 30, 2011 | 06:21 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
This #5 is a repair kit that has a number of clips inside the box. It is 4B0-877-165 for 15.19 dollars.
HJ Matroni
Jul 19, 2013 07:20 PM
CRuby
May 30, 2013 04:54 PM
ahnorman
Mar 13, 2011 10:29 AM
Sanjoy
Feb 14, 2011 09:05 PM
jasonrann
Dec 9, 2006 04:12 PM
