Validate MPG on 07 A4
real deal is CVT's have an ifinite ampount of ''gears''
search CVT transmission on www.howstuffworks.com its the best way to explain a cvt transmission i have found
yea you got the right idea now. the name explains it all. continuously variable transmission. there are a couple different designs but basically they dont have actual gears that have to be engaged or disengaged. when you switch into S or tip mode, the car uses a driving program to imitate the feel and function of actual gears. audi makes a program that tells the transmission to stay in a certain range, like a traditional gear. so theoretically, you could design a program and create any number of 'gears'
p.s. iv driven a nissan maxima with cvt and it was pretty cool. it had a v6 and plenty of pull and felt good gettin on the highway and what not. takes a little getting used but i would recommend if quattro is not necessary for you. up here in ny i like my quattro
Do any of you that have CVT's get a little shudder from the drive line at about 10MPH when coming to a stop? The loaner I had did that. It was almost like the CVT wasn't adjusting gear ratio's fast enough, causing the engine to lugg for a second or two. I was curious, so I did some investigating, and found that there is a TSB about this very thing. Apparently there is a software tweak that gets rid of the shudder/lugging sensation.
thanks!
