weird transmission? rattle
Old Jun 10, 2014 | 06:23 PM
imaudi5000's Avatar
Default weird exhaust rattle
ok, so this noise started yesterday when i was running some errands. did city and hwy driving and everything seems fine, but this rattling/tapping/vibrating noise happens when i put it in reverse. i think it does it a tiny bit when in drive and sitting still but its the most noticeable in reverse. i checked under the car in a parking lot but couldnt see anything wrong, im about to crawl under and get a better look with the belly pan off. just wanted to post and see if anyone had any idea what it could be. here a vid that has the sound, sorry its quiet just turn up the volume
https://www.youtube.com/watch?v=nTUS...ature=youtu.be
Last edited by imaudi5000; Jun 10, 2014 at 10:50 PM. Reason: found problem i think
Old Jun 10, 2014 | 10:56 PM
imaudi5000's Avatar
ok i think i found the problem. it appears to me that the exhaust pipe is touching and rattling against a small cross member in the middle of the car. makes sense because it seems to be loudest in the middle of the car and the 'rough' idle in reverse would cause more rattling. i can see that the clamps are turned/broken, so i rotated it a lil bit so that it wasnt touching the cross member.
i guess now the question is what part of the exhaust is this? is there a joint here? i know i need to have it fixed but money it tight right now so itll have to wait. im wondering how serious this is because i know CO gas and exhaust fumes can be hazardous but i dont know if there is a leak or gap in the pipe/joint.
Attached Thumbnails weird transmission? rattle-imag0781.jpg   weird transmission? rattle-imag0780.jpg
Old Jun 14, 2014 | 10:45 PM
imaudi5000's Avatar
anyone know what part this is and if this is a DIY project?
Old Jun 14, 2014 | 11:11 PM
imaudi5000's Avatar
i found this and it give me hope i also found the part online for like $14. looks like im gonna order some stuff and try to tackle it myself. hopefully this is the only problem part on the exhaust.
Audi A4 B7 2.0T STaSIS Exhaust & 034 Motorsport HFC Install | Audiction.com
Old Jun 19, 2014 | 10:11 PM
imaudi5000's Avatar
Default fixed exhaust clamp
i did it!!! i fixed myself today pretty easily. turns out that the clamps were rotted through and this caused an exhaust leak and rattled against the cross member. i used the diy above to figure out how this part worked and bought a new one online. i bought one from ECStuning but sadly they sent me the wrong one so im in the process of returning it. so i had to run out to the dealer and buy the factory part for $50. the correct clamp/sleeve has a 55mm diameter and ECS sent me one with a 60mm diameter. anyway, i was able to take off the old one and slide the new one on just by pushing the pipes to the side and i didnt have to take off the cross member (didnt have the right bit).
the new clamp/sleeve works great, no more rattle or exhaust leak!! yay!!
keywords: 2008 audi a4, exhaust leak, dual clamp exhaust sleeve, exhaust rattle
sony
Sep 24, 2013 07:49 PM
moneyfresh
Dec 15, 2012 02:01 AM
Christopher Nemitz
Oct 15, 2012 10:00 AM
seanmh
May 27, 2009 04:05 PM
kerNol
Jan 27, 2009 09:24 PM
