Wheel offset? Help!!
I have a 2007 a4 Sline and will be putting new rims on. If I get 20x8.5 rim should I get a 32mm offset or a 42mm offset. I want the wheels flush with the fenders. If someone can help it would be greatly apprieciated.
ET42 would be closer to fitting properly than 32. Most of the factory wheels for the B7 that are 8" wide use a 40mm offset so the additional .5" width on a 42mm offset wheel might require a spacer to get closer to say 38mm for proper fitting.
