Wheels PLEASE HELP
I want to get rims for my a4 b7, dark blue.
i know i want to go up in size and go a little wider.
I would like input as to whether i should get 18s or 19s and how wide i should go.
I also want to know what the "offset" and "hub bore" are.
i like these wheels and am wondering if they would fit?
http://www.elites-wholesale.com/Shop...id/0/SFV/32431
all i know is my cars bolt pattern
also want help with what tires to get haha
THANKS!
-adam
THANKS!
-adam
Our hub bore is 57.1 mm. If I recall, the S-Line wheel offset is ET42, but that requires spacers to bring it out more if you want it flush.
The stock tire on S-Line wheels is 235x40R18, so if you go up to 19 you'll want a lower profile to keep a similar outer diameter.
The first number is the width (in mm), then the aspect ratio (profile), then the wheel diameter.
You can check out this website to see what the effect of changing these parameters is: http://www.1010tires.com/tiresizecalculator.asp
AKAUDI
Jan 29, 2015 07:56 AM
eddieau12di
Jan 11, 2013 05:05 PM
OG_35
May 25, 2010 12:11 AM
irwins41
Aug 17, 2009 10:41 PM
PlatinumAuto
Mar 6, 2009 12:36 PM
