Whistling / Bearing Noise In Engine
Old Oct 9, 2011 | 03:42 PM
Chris_2180's Avatar
Default Whistling / Bearing Noise In Engine
I have a 2006 A4 with 107K miles. It recently started making a whistling noise after it has warmed up. It only makes the noise when it is at idle or decelerating. It whistles both in park and neutral. It sounds like a bad bearing to me, but it continues for a few seconds after the motor has stopped. I cant tell exactly where the sound is coming from but it appears to be loudest between the firewall and motor.
This is my first Audi, and I dont want it to be the first time I have to take one of my cars to a mechanic to diagnose a problem, but I am stumped.
Thanks for any advise!
Old Oct 9, 2011 | 05:16 PM
02A6Beau's Avatar
what motor?
first guess is auxiliary coolant pump
good luck
Old Oct 9, 2011 | 05:37 PM
Chris_2180's Avatar
Sorry, I missed a key piece of info. It is the 2.0t
What would cause the secondary coolant pump to continue to whistle after the engine has stopped?
Old Oct 9, 2011 | 05:51 PM
Chris_2180's Avatar
I answered my own question with regards to the Aux pump myself.
Old Oct 9, 2011 | 08:12 PM
B7Night's Avatar
Someone on the forum reported some whistle sound like that at low rpm and just after shutdown, and it turned out that the PCV valve was plugged and not functioning correctly. Wonder if that could be the issue.
Old Oct 10, 2011 | 10:39 PM
Chris_2180's Avatar
Thank B7. I replaced the PCV this evening, and it appears to have fixed the problem.
Old Oct 11, 2011 | 12:19 AM
krmktk's Avatar
Default Audi weird whistle noise
I have exactly the same problem, it was a 3 second whistle in the beginning, but now I am having this trouble every time that the engined warmed up...any solution or suggestion?
Old Oct 11, 2011 | 12:23 AM
esandes's Avatar
Banned
yeah that stock PCV is a POS. i ignored the whistle at idle for 20k km and i finally took it to the dealership and it was the POS PCV. she ran like new after i got the most recent PCV installed.
Old Oct 11, 2011 | 12:45 AM
krmktk's Avatar
Default pos pcv
sorry my stupid question but i could not find that part on the engine...where is it located?
Old Oct 11, 2011 | 07:47 AM
aetius's Avatar
The PCV is under the plastic engine cover (where 2.0FSI turbo, and Audi rings are). Pull it straight up and you will see the PCV under it. It is black, round and has a plastic tube connected to it. Mine went at 24tmls. The only symptom my car had was oil being pushed out around the oil filler cap.
