wondering is it good to change the DV to new fsi one?
Old Mar 4, 2009 | 05:16 PM
07titanium's Avatar
Question wondering is it good to change the DV to new fsi one?
Genuine Volkswagen Audi - Upgraded Piston Diverter Valve, Electronic ES#259456
One of the weakest spot on any chipped 2.0T cars is the diverter valve. The factory diaphragm can crack under high boost pressure, and create a massive boost leak. This OEM valve from the new FSI motors features an upgraded piston type design, modeled after the more expensive aftermarket units. This is the perfect solution for anybody needing an upgraded DV, that doesnt want to void their warranty with "aftermarket" parts
Old Mar 4, 2009 | 10:20 PM
eMacPaul's Avatar
Later model year DVs are stronger than the earlier ones (not sure exactly when the switch happened) so you might not need it at all.
Old Mar 5, 2009 | 04:04 AM
Quattros's Avatar
revision H is the current one or G. holding up strong.
Old Mar 5, 2009 | 07:45 PM
07titanium's Avatar
Default audi piston type diverter valve vs diaphragm valve
thanks alot for your reply
my is 07 b7 purchase it doing end of sept in 06 so i was wondering do i need to upgrade
it to the piston type cause dealer is charging 135 labor to do it ..
stutters11b
Feb 16, 2014 11:02 PM
vrso2
Feb 5, 2008 10:45 AM
stealthyghost
Jul 14, 2006 03:10 AM
