2010 a4 quattro milage question
Old Feb 27, 2011 | 06:09 PM
chaolanren's Avatar
Default 2010 a4 quattro milage question
Hi guys i am located in CA and just wondering what milage you guys were getting in your a4 quattros.
I usually do 91 gas highest here and i usaully only getting 300 miles per tank driving a freeway local mix.
is it weird?
Old Mar 4, 2011 | 01:25 AM
ADK_audi's Avatar
Yes, I would say that is on the low side, but I guess it depends on how you drive and driving conditions. I can get over 400miles per tank if I drive like a normal person in mix type driving, but I usually get about around 350 with a spirited foot. If you are a driver that is either-on-the-gas-or-on-the-break then around 300 is probably right, maybe a little low.
Old Mar 8, 2011 | 02:18 AM
dCHARizard's Avatar
I also live in CA. My trip computer says I can get 410 miles after I fill it up. Some mornings, it says I'm getting 32.0 mpg. But realistically I usually get 320-340 miles per tank.
Old Mar 8, 2011 | 03:48 PM
esandes's Avatar
Banned
300 miles per tank is bad milage for alot of freeway driving. you must floor it alot. this is a long shot but maybe check your tire pressure. then again, you may be filling up with a bunch of gallons still left in the tank. when the gauge is close to red, you still have quite a bit of gas left.
take your milage trip counter reading before filling up and divide it by the gallons you fill up with.
Old Mar 24, 2011 | 11:08 PM
vfr800's Avatar
Default trip computer not accurate for mpg
We are getting around 340 miles per tank. It is worth noting the trip computer is typically not accurate +2 mpg. Other "lesser" cars owned were within tenths of measured readings. Another point on fuel. When adding fuel, when the pump shuts off, it is full within ounces, otherwise spillage.
Old Mar 30, 2011 | 05:18 PM
GodFathersA4's Avatar
I get around 390 to 405 as per the comp. But with my driving habits I would say 340-350ish tops. In Cali also.
Old Apr 4, 2011 | 09:51 PM
tommyo4's Avatar
I am getting right at 300 per tank too. I upgraded my wheels to the S5 wheels and ever since I saw loss in about 30 miles per tank. I even tried doing a cai to help and it made it worse.
Jason Benson
Audi Q5
Feb 15, 2013 01:28 PM
JOLLYROGER
B8 Models
Sep 25, 2010 11:33 AM
az3turbo
Jul 21, 2007 11:27 PM
sound227
May 24, 2007 11:22 AM
RLB6
Jun 29, 2006 04:16 PM
