crankcase pressure regulating valve
Old Jan 2, 2014 | 10:20 PM
icurn747's Avatar
Default crankcase pressure regulating valve
I have a 2010 a4. It is putting up a "lean at idle" code. If I get it above 4500 rpm the EPC light comes on. I turn the car off and back on and it goes away. At idle there is vacuum coming from a small hole on the crankcase pressure regulating valve. Is that my problem?
Old Jan 3, 2014 | 10:53 AM
M5S5's Avatar
Tech Certified
Bad crankcase valves usually affect idle conditions. try pulling the oil cap off with the engine running , if it is difficult to pull off the valve is bad.
Old Jan 3, 2014 | 01:44 PM
i7believe's Avatar
I've had this issue as well except I had that system too lean CEL/code permanently. If there is a oil residue around the oil cap area and too much suction (engine about to stall when you remove) then valve is probably going bad.
I changed the PCV valve, PCV hose. Also this cured the oil burn problem as well.
Old Jan 3, 2014 | 02:18 PM
icurn747's Avatar
I had the oil burning problem. The dealership had to install new pistons 3 time. Had my car for almost 2 month. And in those 2 months I went through 3 loaner cars. The first 2 had oil consumption problems if you could believe that. They did get mine fixed and it is doing very well. I haven't had to add any oil in almost 12 months and 30,000 miles! Anyway, thanks for the advise. I will try the oil cap when I get home today.
Old Jan 3, 2014 | 06:06 PM
icurn747's Avatar
Ok, it almost took two hands to pull off the oil cap. I guess that means it's bad. Where is the best place to get one? If I have to buy something I always like to upgrade, is there an upgraded valve? Thanks...
Old Jan 4, 2014 | 12:27 PM
icurn747's Avatar
Installed a new CPR valve today. I have reset the check engine light and drove it about 30 miles. The check engine light did not come back on. The EPC light still comes on if I go over 4000 rpm and it goes into safe mode. Any ideas on why this is? When the EPC light comes on it does not throw any codes...
A6Isaac
Feb 10, 2014 06:56 PM
Ritchie
May 26, 2012 03:06 PM
nkasco
Sep 25, 2011 03:58 PM
jetmech
Nov 5, 2010 05:27 PM
tunaglove
May 28, 2009 10:04 AM
