:: ECS Tuning :: 8 A4 2.0T Quattro ST Performance Coilovers - $100 Mail In Rebate!
Old May 13, 2014 | 01:11 PM
ECS Tuning's Avatar
Sponsor
Default :: ECS Tuning :: 8 A4 2.0T Quattro ST Performance Coilovers - $100 Mail In Rebate!
The lowered ride height achieved by upgrading your factory suspension is a consequence of the modification, not its purpose.
With this knowledge, you can appreciate the value of more finely wrought suspension designs, like those from ST.
The ST-line Performance Coilovers utilize tempered high-strength springs, hardened chrome piston rods, and galvanized zinc-plated strut housings - a consequence of which is a powerful, aggressive stance. But the enduring value of this arrangement lay in its durability, reliability, and reverence for precise engineering.
Features include:
  • Adjustable composite spring seats
  • Tempered high strength springs
  • Compression bump stop with integrated dust boot
  • Hardened chrome piston rod
  • Noise damping, corrosion resistant spring cap
  • Galvanized Zinc plated strut housings for corrosion resistance
  • All ST coilovers meet German TüV standards
  • 5 year limited warranty to the original purchaser
** Special Note: Audi vehicles equipped with Electronic Damping Control have front and rear OE dampers with electrically-operated actuators that change damping, on command.
To prevent dash light illumination, a set of four resistors must be mounted and connected to the open harness plugs at each wheel. A complete set of circuit resistors is available from ECS Tuning (ES2608438) for installation with both KW and many other coilover kits. The resistors come with mounting brackets and exact-fit original equipment connectors. Adding them is a simple plug-and-play installation that will keep the dash light off.
Drop It!
Click HERE to order or for more information
Fits:
Audi B8 A4 2.0T Quattro (2009+)
Rebate eligibility ends 5/31 all forms must be received by 7/31
Let me know if you have any questions.
Jason
