Pressure Valve on Coolant Reservoir?
Old Apr 16, 2022 | 03:06 PM
2009a4b8's Avatar
Default Pressure Valve on Coolant Reservoir?
My engine overheats when stationary for an extended period of time and the A/C isn't very cold—I am pretty sure my Radiator Fan Assembly needs replaced. Today, I noticed coolant leaking from under my car and when investigating further, the coolant reservoir was boiling and emitting pressurized steam. Is this some sort of safeguard?
Old Sep 16, 2023 | 01:47 AM
jtnly1's Avatar
Hey Man, did you ever get this sorted out - what was wrong with it?
Old Sep 16, 2023 | 04:28 PM
2009a4b8's Avatar
I took everything apart and found that some asshat disconnected the radiator fan. It turns out that there is also a hole where the coolant reservoir cap threading is that allows steam and excess coolant to be expelled when under pressure. A year later I am in the same boat again--this time I think it's the coolant pump.
Old Sep 16, 2023 | 05:12 PM
jtnly1's Avatar
oh wow... thanks for the reply...good luck in sorting out..I'm in the same boat
Old May 13, 2024 | 09:17 AM
kylebraxtondaniel's Avatar
Exclamation Coolant Leak /Over heating
Good Day Bud,
I have a similar issue with my b8 1.8 tfsi- I have coolant boiling overflowing from my reservoir, engine also overheats , however ever when I turn the heat on, the temp does not go pass 70, no coolant over flow, boiling or engine overheating.
I have replaced (with a used unit -just for testing purposes) the thermostat housing + water-pump , however issue still seems to persist.
Not sure what this issue could be.
GLD
Dec 6, 2008 05:22 PM
mcicoria
Aug 23, 2006 12:09 PM
bxaffiliant
May 26, 2006 01:21 AM
