Winter Wheels & Tires
Old Oct 15, 2010 | 01:43 PM
ADK_audi's Avatar
Default Winter Wheels & Tires
I need some help. I have a 2010 A4 w/ the 19' Sport package but I need to get some Winter rims and tires. Can someone provide me with the info on my current wheels? I have searched around but can't find info on these specific wheels.
Also, I am looking for recommendations on winter wheel and tire options? Should I go down to 18s?
Any help you can provide would be appreciated. Thanks!
Old Oct 17, 2010 | 02:43 AM
jaystsx's Avatar
Can't comment on your current wheel's specs.
For snow/ice tires, yeah, you should probably drop one maybe even two sizes/. Skinnier, taller tires have an easier time knifing through large amounts of snow. Plus, with a smaller contact patch, you have more weight per square inch making contact (better traction).
Tire Rack is a good starting point, in my opinion.
Old Oct 17, 2010 | 03:13 PM
wpg2.0T's Avatar
I am running a set of Audi 2009 10 spoke 17x8 wheels and 245x45 R17 Yokohama W-Drive winter tires on my '11 Avant S-Line.
I believe you could also use 225x50 R17 tires.
Old Oct 17, 2010 | 05:00 PM
turbo kraut's Avatar
Tech Guru
i have a set of 5 b5 s4 wheels in black, 500 shipped, you would need at least 4 new tires...
Old Oct 19, 2010 | 10:25 AM
hiwords's Avatar
all OEM audi wheels from B7 and earlier will not fit the B8. the hub bore is too small.
OP: what you need is a set of 17s (preferably) with a hub bore of at least 66.56mm. ET doesn't matter too much but stay within the +38 to +42 range. get a set of 225/50/17 tires and you'll be golden
Old Oct 20, 2010 | 12:17 AM
esandes's Avatar
Banned
just go to tirerack.com and input your make and model with the optional tire size. it'll pick the tire specs for you. i just picked up a set of continental extremewintercontact for the golf and a set of continental extremecontact DWS (all season) for the audi. both are highly rated.
Old Oct 22, 2010 | 08:48 PM
ADK_audi's Avatar
Hey, I am going to tee this up... I have a pretty dumb question. I was offered B8 S4 wheels, those would fit, right?
Old Oct 24, 2010 | 11:02 AM
hiwords's Avatar
yes they will but be ready to pay out the *** for snow tires for 18s
Old Oct 24, 2010 | 03:04 PM
flew66's Avatar
18" Winter tire typically costs $50 more than the 17" each, i.e. ~$200 a set. From a cost stand point, if the B8 S4 wheels are priced right, I would take them.
One consideration though, narrower tires have better snow traction in general. So, 17" tire would be better if your winter driving involves going through a lot of deep snow.
Old Oct 27, 2010 | 10:37 PM
ah12's Avatar
This will be my first winter with my 09 A4. I'm sticking with the 18" Yokohama all-season tires and we'll see how they do. I live in the midwest where the winters are brutal so I'm hoping the AWD will compensate a bit for my lack of specific winter tires. We will see!
