:: ECS Tuning :: NEW!! ECS Baffled Catch Can System | Audi B9 A4 2.0T
An unfortunate consequence of the modern closed PCV/breather system is the unintended ingestion of oil vapor and carbon into the intake tract. Thus lowering the octane rating and leaving harmful deposits on a vehicle's intake valves and ports that result in decreased power.
Engineered in-house and manufactured here in the USA, the ECS Baffled Oil Catch Can uses a highly efficient 4-chamber oil separator, decreasing oil ingestion and maintaining engine power output.
The innovative design also catches as much blow-by gas as possible, bringing carbon buildup to an absolute minimum.
Key benefits of the ECS Tuning Performance Baffled Oil Catch Can System:
- Highly Efficient Oil Separator (Catch Can):
- Strategically positioned 4 chamber baffle system maximizes oil / air separation
- Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
- Knurled and black anodized integrated oil dipstick makes inspecting oil volume of the reservoir clean and simple
- Fully serviceable for routine cleaning and maintenance; Includes 2.5mm allen key to remove baffle plates for cleaning
- -10AN ORB (O-Ring Boss) fittings for leak-free fitting connections
- 6061-T6 billet machined body, anodized black for lasting protection and appearance
- Easy to drain reservoir, simply un-threads from the oil separator for quick draining or cleaning
- The OEM Audi fine oil (cyclonic) separator is retained. Due to the retention of this component, the catch can will not have to be emptied as often, as its focus will be on capturing the ultra-fine oil vapor*
- Engine cover fitment is maintained with no modifications needed
- Completely reversible installation, as no OEM components are permanently modified
- OE style appearance once installed
Carbon No More
Click HERE to order or for more information
Fits:
Audi B9 A4 2.0T (2017+)
Be sure to check out our -----> Installation PDF <-----
Let me know if you have any questions.
Jason
ECS Tuning
May 25, 2017 11:07 AM
ECS Tuning
B8 Models
May 25, 2017 11:04 AM
ECS Tuning
May 12, 2017 03:31 PM
ECS Tuning
S3
May 2, 2017 03:04 PM
ECS Tuning
Apr 22, 2016 04:09 PM
